Hey
Wonder if you can help me,
I have A Hercules DJ Console.. and I want to Broadcast my show over the internet. Aswell as Record my shows.
Anyway,
When i go to do my show, it says..
** Record Error **
Can't Open MP3 Encoder.
I have it automatically set to use the encoder,
C:Program FilesVirtualDJlame_enc.dll
So do i need to download this lame encoder?
Also when i try to Broadcast it says,
** Broadcast Error **
Encoder Error
Please Help :)
Thanks!
Anyway,
** Record Error **
Encoder Error
Please Help :)
Thanks!
Posted Tue 05 Jun 07 @ 2:53 pm
I'm afraid so. You can use WAV, but it uses a lot of memory - laptops' memory is not very big - about 80 GB on average - though you can get extension hard drives - too much stuff in your computer can also slow it down.
I think the more recent versions of the Virtual DJ software have the LAME encoder installed as standard.
Posted Tue 05 Jun 07 @ 3:30 pm
Seaneh wrote :
** Record Error **
** Record Error **
Firstly make sure that ur lame _enc .dll is still in ur Virtual Dj folder in the c drive cos if u move it out from that specific location it could post as an error. Hope that helps.
Posted Tue 05 Jun 07 @ 3:36 pm
Hey.
Thanks for the reply but where can i get this Lame Encoder?
And where do i need to install it to once i find it.
Thanks :]
Thanks :]
Posted Tue 05 Jun 07 @ 4:10 pm
It should be in ur virtual dj folder.. if u cant find it , try reinstalled maybe u accidentally delete it. I will check for u in couple of hours by the time i reach home..
Posted Tue 05 Jun 07 @ 4:13 pm
Ok Thanks :]
I think i found it at..
http://www.free-codecs.com/download/Lame_Encoder.htm
But im not sure if thats the one and where do i save it to?
Posted Tue 05 Jun 07 @ 4:14 pm
Fixed guys - Hopefully anyway!
Thanks to everyone at VDJ :))
I downloaded that and placed the particular file into my VirtualDJ folder and now it works ;]]
Thankoo!! xD
Thankoo!! xD
Posted Tue 05 Jun 07 @ 4:38 pm
nice... :) have fun
Posted Tue 05 Jun 07 @ 6:30 pm
am gonna go online who wants to tune in
Posted Tue 28 Jul 15 @ 9:46 am
LOCKED BY AMAHM
Posted Tue 28 Jul 15 @ 11:53 am
