Hey,
I am just running the MK2 and trying to play the music through my computer speakers. I can only hear music coming out of the headphones when it is on mix or split mode. Under the sound setup in the config here is what I have:
Inputs: None
Outputs: Single Output
Sound Card: DJ CONSOLE M2K
It used to work with no problems but then I tryed config it so I could use the headphones off the M2K and the stop the audio from coming out of the speakers. Any help would be appreciated. Thanks guys
Inputs: None
Posted Sun 25 Mar 07 @ 8:17 pm
are you using console edtions are the speakers hooked up to the console?
Posted Sun 25 Mar 07 @ 8:40 pm
Sky are you able to change the sound settings on the home edition???
If you are then here is the one you want
Inputs: None
Outputs: Headphone
Inputs: None
Outputs: Headphone
Posted Mon 26 Mar 07 @ 4:53 am
Hey,
nope my speakers are connected directly to my computer. thanks again
Posted Mon 26 Mar 07 @ 5:35 am
Well thats the problem, the speakers should be connected to the MK2 not the computer. Try the settings I told you with the speakers connected to 1/2 on the MK2.
Posted Mon 26 Mar 07 @ 8:02 am
to use more than one card you need pro
which is available at a
discount to mk2 users
Posted Mon 26 Mar 07 @ 12:08 pm
sounds good, I actually connected the speakers to the M2k last nite. But when I first hooked it up to my computer , I had everything running great with audio coming out of the computer speakers. Not a big deal though. Thanks for the helP!
Posted Tue 27 Mar 07 @ 1:52 am
Glad you got it sorted!
Posted Tue 27 Mar 07 @ 11:59 pm
Posted Wed 28 Mar 07 @ 12:35 pm
