not sure if this a problem with the hardware or the software... while using TCCDs with my MK2, i have expierenced a weird skipping problem while loading tracks. when i load the track it starts and stops very quickly, creating a skipping/scratching sound over the top of the mix regardless of what position that channel's volume is at. if i look at the virtual decks in the software i can see the needle moving back and forth from at rest to the edge of the record. the play button also flashes on my MK2 as if it is being pressed repeatedly. this doesnt happen all the time, its completely random and the only way to resolve is to restart my whole comp and sometimes that needs to be done several times. in worst cases, the skipping causes the currently playing track to restart from the begining. this is very aggravating and i dont know if it is a bug with TCCDs and the software or maybe a problem with my MK2. when the software works it works great! :) Has anyone else had this problem? Any help would greatly be appreciated!
Specs:
Toshiba Satellite- Pentium 4 2.66 GHz, 480 Mb RAM
160 Gig external HD
VDJ w/ TCCDs
Herc MK2
2 Cdj1000 mk3
DJM800
No Spyware or virus problems & all uneccessary programs & processes are disabled while running VDJ
Specs:
160 Gig external HD
VDJ w/ TCCDs
Herc MK2
2 Cdj1000 mk3
DJM800
Posted Wed 07 Mar 07 @ 3:39 am
