Hi
I have been using VDJ for some time now, and lately as I upgrade to the latests versions I have noticed that, when loading a file on one of the decks if the other is playing there is a split moment specially at the end of loading, that the program tends to slow down, sometimes if at that moment I decide to remove the loaded file then the program just stops responding (crashes).It happen last night 4 times in 1 hour.
I have gone back and installed version 3.3 it works better, but because I sometimes use the Hercules console it does not allow me to go back to other versions.
I have also changed to much lighter skins but the problem still there, I'm now a little bit less confident when using the program.
I thought that the problem was with lack of memory I had 256Mg so I upgraded to 512Mg and the problem is still there.
The specs of my laptop is CELERON 2.6, 60Gb HDD, 512Mg MEM
If there is anyone that can help me I would very much appreciate, I'm even reconsider in buying a new laptop, but maybe there is a simple solution
Posted Sat 03 Mar 07 @ 12:24 pm
          512 ram is still a bit low
on v4.2 there is an option to adjust proformance
try on this
fastest
untick overclock and safe mode and choose autolatency
try on this
fastest
Posted Sun 04 Mar 07 @ 1:47 am
          paul, don't feel alone, I have a 2 gig ram and had the sdame thing happen, and i had to do what you did, however, accordibg to the pro's here, 4.2 is still the one to stay with, if you can get it to work?
    Posted Sun 04 Mar 07 @ 8:12 am
          You have to replace your processor try Pentium not Celeron.... Pentium is best  processor
preformance and more faster than celeron.... Celeron is 50% percent slower from Pentium....
thnx God Bless all the DJ's......
Posted Sun 04 Mar 07 @ 11:55 am
