Hi there . i recently bought a mk2 console but i have some sound bug issues.
Well let’s start.
I use a laptop with a usb sound card and logitech z5500 speakers
http://www.jdr.com/images/products/L/logi-z5500.jpg
I connected both tts with mk2 (grounded them) and the outputs of mk2 to phono inputs of my mixer. Also from the mixer i pushed a little button that switches from phono to line.
Ok then i plugged a cable from the master output of my mixer not to the usb sound card (it doesn’t have inputs. Only outputs) but to the logitechs line in. You can see it to the next picture
http://img5.pcpop.com/ArticleImages/240x180/0/333/000333129.jpg
when i plug this cable and when my mixer is on i get this sound
http://www.yourfilehost.com/media.php?cat=other&file=strange_noise.amr
but when i turn off the mixer the sound becomes less noticeable. (only if i turn on to the highest level the speakers i hear it)
if then i unplug the mk2 console the sound is copletely off.
I checked well all the grounds and bought brand new cables for all of my gear but the problem still exists. What do you think it is?
I read somewhere to unplug the ac adapter from the laptop and use it with the battery but nothing.
Note that the problem with the sound stays even i don’t open the vdj
Well let’s start.
Posted Tue 27 Feb 07 @ 1:19 pm
anyone that could help me please?
Posted Wed 28 Feb 07 @ 5:48 pm
try a powered usb hub , or the ac adaptor
Posted Wed 28 Feb 07 @ 8:15 pm
why to use a powered hub?i plugged it to a normal usb 2.0. also i said that already tried the trick with the ac adapter. unplugged the adapter and used the laptop with it's battery but still nothing
Posted Thu 01 Mar 07 @ 12:32 am
you get same noise with laptop running on batteries only??
It sounds very much like ground loop.
Try connecting your audio stuff (pc, mixer, speaker) on different power outlets .
Posted Thu 01 Mar 07 @ 12:36 am
it's the third time i will say that yes even with the battery i get the same noise
Posted Thu 01 Mar 07 @ 4:27 pm
well, if running on batteries doesnt help, then try reinstall the drivers.
And if that doesnt help, return the unit to the shop.
It might be broken...
(sounds exactly like a ground loop that RealPlayer file, so sorry for asking about the batteries again)
Posted Thu 01 Mar 07 @ 6:05 pm
any other suggestions?
Posted Sat 03 Mar 07 @ 12:34 pm
