I want to be able to preview my mixes in my headphones.
My sound card has 6 jacks, one green, one blue, one black, one pink, one yellow and one grey. Additionally, I have a microphone and a headphone jack in the front. I can use my 2.1 speakers or my headphones on the headphone jack in the front or the green jack in the back. I can not, however use both at the same time (same sound, not a preview). Ive tried plugging both into all the other jacks, with all the different sound setups under config. Im assuming my sound card is at least a 4.1.
Thanks in advance!
Thanks in advance!
Posted Tue 20 Feb 07 @ 1:00 pm
on sound options choose
input :none
output : headphones
card : your card 4.1 or better
and then assign channels for main and headphones this way you can choose what output for it to come out :)
which model is your card?
input :none
output : headphones
Posted Tue 20 Feb 07 @ 1:14 pm
Connect speakers and headphones in the rear panel of your sound card.
Green (Front) --> speakers
Black or Grey (Rear) ---> Headphones
Be sure you have enabled from the sound setup of Windows, your sound card setup (4.1 or more).
Posted Tue 20 Feb 07 @ 2:42 pm
ive tried plugging them both in the back,
my sound card is sigma tel (from dell),
ive tried to find those setting sfor my sound card it seems it just has the most basic ill look for a cd though
Posted Sat 24 Feb 07 @ 8:52 am
