I have the hercules mk2. i just wanted to know if there is any way i can open virtual dj without the Hercules?
Posted Sat 10 Feb 07 @ 4:59 pm
And..... if i buy numark cue, can i use my hercules mk2 with it? and if i wanted to plug cd player in it, could i ?
Posted Sat 10 Feb 07 @ 5:14 pm
The free version you got with the Hercules, can only be used with Hercules connected.
But the full pro version of VDJ or Numark Cue, can of course be opened and used without the Hercules :)
And you can connect cd decks to the Hercules MK2, with timecode cd's, and control VDJ with the cd players.
You can also bypass when connected, so that the audio of real CDs are sent to mixer
hope that helps :)
Posted Sat 10 Feb 07 @ 5:19 pm
so does numark que work the same as virtual dj? and if i get numark cue, can i download samples and skins ect.?
Posted Sat 10 Feb 07 @ 5:22 pm
yes :)
Numark Cue gives same forum level as Virtual DJ :)
Posted Sat 10 Feb 07 @ 5:25 pm
thnx. now i know who to ask questions!
Posted Sat 10 Feb 07 @ 5:29 pm
oh yeah i just rememberd. what is that sound or break that djs use to scratch? everyone uses it. i cant find it!
Posted Sat 10 Feb 07 @ 5:32 pm
"fresh" probably :)
http://www.rollerskates.com/dj/js1.rm (at the very end of the sample track)
http://www.skatesonhaight.com/DJ-JS1-Scratch-Roulette-2-LP-p/fbdjjs1sr2.htm
Lots of good scratch samples to be bought.. Just search for DJ tools :)
Posted Sat 10 Feb 07 @ 5:41 pm
thnx alot
Posted Sat 10 Feb 07 @ 5:43 pm
