Hi,
I bought a the Hercules DJ Console some time ago which ships virtual DJ version 1.09.
I want to record from the line in phono connection but can't seem to do this ?
I can't see any option to use the line in as a source ?
Is this a limitation of the version of V. DJ I have ?
That would be a bit of a liberty if the hardware has come shipped with software which can't do the job.
Any help appreciated.
Thanks.
Thanks.
Posted Sat 03 Feb 07 @ 12:18 am
the software it came with is now 4 and a half years old.
if you want advanced features you need to upgrade the latest version
Posted Sat 03 Feb 07 @ 12:38 am
