Why do I need to buy MK2 if I'm only going to mix on the computer? Is there any reason why not go for the Hercules MP3 then I wonder?
Haakon
Haakon
Posted Sun 28 Jan 07 @ 4:36 pm
mk2 has a soundcard and can be used for previewing and timcoded vinyls
mp3 contol has no soundcard and is just a simple midi controler
Posted Sun 28 Jan 07 @ 4:46 pm
soundcard, ok, so what is that good for?
Posted Sun 28 Jan 07 @ 4:49 pm
you need a soundcard so you can play music and listen to the preivew
if you already have a 4.1 plus soundcard you might not want it
but personaly i think mk2 is much better unit/deal
Posted Sun 28 Jan 07 @ 4:57 pm
Ok so you strongly recommend the MK2. Then MK2 it is! Thank you so much for the help, really appreciate it! :)
Posted Sun 28 Jan 07 @ 10:19 pm
just be sure to read all of the problems mk2 has.
sound quality is good, but there is also static. (speaking from experience)
DJ Shahar
www.djshahar.com
DJ Shahar
www.djshahar.com
Posted Sun 28 Jan 07 @ 10:29 pm
what do you mean? does MK2 have problems that MP3 doesn't have? what kind of problems could that be?
Posted Sun 28 Jan 07 @ 10:48 pm
that is due to bad insulation of cables and power sources and part of all cards
and is easily remidable for all cards
buy using different plug for your amp than ur laptop
or using a grounded powerstrip :)
Posted Sun 28 Jan 07 @ 10:49 pm
also have another question. do any of you know an internetshop that sells this Hercules consoles that is cheap and ships to other countrys? perferably in english..
Posted Sun 28 Jan 07 @ 10:50 pm
Now I get the big difference the consoles between, with the MP3 it is not possible to listen to headphone before you play the song. that is quite useless then, can't mix for real then!
MK2 it is!
MK2 it is!
Posted Sun 28 Jan 07 @ 11:01 pm
where do you live?
Posted Sun 28 Jan 07 @ 11:05 pm
Sweden!
Posted Sun 28 Jan 07 @ 11:09 pm
try amazon they ship it world wide :)
Posted Sun 28 Jan 07 @ 11:10 pm
well, thanks, but it's not that cheap. About same cost here in Sweden, and here I can pay instalment to! :) THanks anyway!
Posted Sun 28 Jan 07 @ 11:15 pm
Another question! Some guy on another forum told me that Hercules was only plastic bullshit, that I shoult buy this usb-mixer NUMARK DXM-01USB instead and it was even cheaper so what's the difference between these?
Posted Mon 29 Jan 07 @ 12:55 pm
has no midi control just a soundcard
Posted Mon 29 Jan 07 @ 12:57 pm
so what those that mean? i'm a newbie :)
what is best?
what is best?
Posted Mon 29 Jan 07 @ 1:25 pm
i learnt the basics with the mk2 its a good all in one unit which will aslo let you use timecodes if you decide to jump to that
some people look down on it because it can have a higher latency than some cards however i posted on my blog a way to get this down to 2ms which is lower than most cards
it aslo gets you home edition free which you can upgrade at a reduced price
but at the end of the day its up to you :)
Posted Mon 29 Jan 07 @ 1:29 pm
Well, of course it is up to me but since I'm so inexperienced I really would appreciate some advices.. but thank you.. I think i still will go with MK2.. it's getting to complicated all of this.. I just want to mix nothing else! :)
Posted Mon 29 Jan 07 @ 2:09 pm
good luck :)
Posted Mon 29 Jan 07 @ 2:24 pm
