Last night at the start of the evening, I set a batch of files to scan for bpm (house/techno setting), afterwards the database showed the song length but not the bpm. When I loaded one of the songs into the deck I noticed that the autogain hadn't been performed and so i had to alter the gain on the screen to get it up to a usable level.
Most of the time it's fine, but just occaisionally this happens.
Anybody else had this problem? Any ways round it?
Posted Wed 24 Jan 07 @ 6:31 pm
so on options have gain match : allways
right ?
have you restarted the program since scanning?
right ?
Posted Wed 24 Jan 07 @ 6:34 pm
Yeh, the gain setting is on always 0dB. Most of the time it works fine, but just occaisionally it plays up.
I rescanned some files tonight at a gig and all was fine, strange! :)
Posted Tue 30 Jan 07 @ 4:11 am
some songs can be trickey and you might need to adjust manualy
Posted Tue 30 Jan 07 @ 11:24 pm
Yeh, this is true. But these files hadn't been analysed at all, hence no auto gain value had been applied to them.
I had the problem again last night, but found that they were scanned correctly if i selected songs one at a time and analysed them.
Posted Wed 31 Jan 07 @ 5:41 pm
