Hi,
Last night I was using VDJ and it started making crackling sounds, when I use the fader. I rebooted twice and it didn't fix it. I have a P4 3.0Ghz with 1.5GB of Ram. i just got done reimaging it. So I don't know what the problem is :O( Is there any updates for VDJ??
Thanks :O)
Thanks :O)
Posted Thu 18 Jan 07 @ 8:08 am
Turn on Safe Mode and try that, also try lowering your performance settings. Also set latency to Auto
Posted Thu 18 Jan 07 @ 8:49 am
if you are using 4.2 no
otherwise
contact support and they can enable the update for you :)
however if you use autlatency and the proformance tab as sugested all should be fine :)
Posted Thu 18 Jan 07 @ 11:56 am
Thanks guys, I will do this tonight when I get off work.
Latin_hick :O)
Latin_hick :O)
Posted Sat 20 Jan 07 @ 2:18 am
Question,
Is there a reason why VDJ start preforming poorly?
Posted Sat 20 Jan 07 @ 5:11 am
bad config on some ones pc. or resources being consumed to fast ie ram or cpu
Posted Sat 20 Jan 07 @ 12:06 pm
