Im having a big party for new years
I need the cheapest and easiest way to be able to listen to one virtual deck in my headphones while th eother deck is playing in the speakers. I have my laptop of course, I have a 4 channel mixxer with 2 channels taken up by 2 cd decks (I have an american audio dj system cheap!!! that comes with teh mixxer and 2 cd decks) I heard something about a y splitter and also about external card!! please help me out as far as the cheapest way to accomplish this.....Im messing with the trial and I know you cant do this with this trail but Im going to buy as soon as I figure this out...my friend has the real version but does not know how to accomplish this..please advise
also how would I connect it all
Posted Thu 21 Dec 06 @ 11:57 pm
try an external soundcard like u46dj
or presonous firebox
if your looking for a package deal try the mk2 u get a soundcard and a controler and virtual dj home edition:)
Posted Fri 22 Dec 06 @ 12:19 am
is there a cheaper way like the y splitter??? i plan to buy the whole deal in january but dont have the cash to buy a firebox..please advise
Posted Fri 22 Dec 06 @ 12:21 am
y splitter makes the sound mono which doesnt sound as good
get an mk2 cheaper
and will do more for you in the long run
aslo you get a chance to upgrade to pro at a discount with it
get an mk2 cheaper
Posted Fri 22 Dec 06 @ 12:27 am
about how much does an mk2 run??? and the sound really doesnt matter to me its just a house oarty
Posted Fri 22 Dec 06 @ 12:48 am
if you mean cost 130 £
Posted Fri 22 Dec 06 @ 1:33 am
Cheapest way would just be getting some external usb 5.1/4.1 soundcard.
Like soundblasters...
Costs about 60dollars... And has the two stereo outs you need...
But you can find cheaper 4.1/5.1 cards too, just not too sure about the soundquality then ;)
A bit more advanced could be the Hercules MK2 as mentioned, as it not only gives you a 2x stereo out, but aslo a midi controller
Costs about 200 dollars.
And hope all goes well, and that we see you as a full member over New Years ;)
Posted Fri 22 Dec 06 @ 2:11 am
A Y-splitter will cost you 2 dollars. In config menu, check on the picture that shows y-splitter, then tell VDJ which channel goes to main and which goes to headphones.
Posted Fri 22 Dec 06 @ 6:18 pm
its mono tho :(
not as good sound
not as good sound
Posted Fri 22 Dec 06 @ 6:25 pm
he did say cheap and with cheap quality goes out the window...
Posted Fri 22 Dec 06 @ 7:31 pm
