I'm using SL-1 with VDJ.
My problem is that after using my VDJ TCVs with VDJ for about 5 minutes, the TCVs won't work. I see the platter in VDJ moving as I move the TCV back and forth but it doesn't control the music.
It's pretty weird... It's like... wait.. it's working... oh... uhh.. no... now it's not..
You know what i mean..
help me out guys.
help me out guys.
Posted Fri 15 Dec 06 @ 6:58 am
could you post any screenshots for us and tell us a bit more about your pc :-)
Posted Fri 15 Dec 06 @ 10:23 am
sounds like its going into timecode off/on mode on the default skin there is a button near the disk saying TC or something. if that has become un-selected that could be the cause
if you are starting from the very start 11 mins later the timecode will go to (to borrow an SSL phrase) 'internal mode' meaning no timecode. if you get to near to the end of the timecode this gets triggered and you need to reset the timecode, you can usualy do this by putting the needle back to the start but you could also try making a shortcut for 'timecode_active' or whatever its called and see if that can wake up the timecode if its gone to sleep on you
Posted Thu 21 Dec 06 @ 7:12 am
