I wanted to make this official...
everytime i boot up vdj4 i have to set my effects all over again. each and everytime i close the program they all reset. is there any way to save my effect settings?
THANK YOU!
THANK YOU!
Posted Fri 08 Dec 06 @ 10:48 pm
are u shutting down the software fully
what settings do you have on the auto reset options
Posted Fri 08 Dec 06 @ 11:00 pm
yes, i am shutting down fully. auto reset? where can i find that?
Posted Sat 09 Dec 06 @ 1:57 am
Only the effect built with the VirtualDJ v4.x SDK and some of the previous effects can save the settings
Posted Sat 09 Dec 06 @ 10:14 am
