I'm a total newb. When I crossfade with the MK2 the volume drops a lot and it makes the mixing sound sloppy and tips?
Trev
Trev
Posted Sun 03 Dec 06 @ 5:35 am
could you post a screen shot of the settings you have
on the mk2 control pannel on tab 2
try www.tinypic.com to upload and get a picture link
Posted Sun 03 Dec 06 @ 11:42 am
if you go into the settings for the controller you will see (in advance) the setting you need to chance the crossfade curve. you should have the MK2 icon in the systray, if you dont goto "all programs" find the hurcules folder and enable it. If you have upgraded your driver then goto the hurcules folder in program files and open it
Posted Wed 06 Dec 06 @ 10:08 am
