I'm having trouble with automix. When enable, VDJ does not SYNC the songs, they enter out of compass.
This didn't happen to me with VDJ 3.4 that in automix the program allways auto activate SYNC button automatically for a moment and the song entered to the right compass then the Sync was auto deactivated by the program.
with VDJ 4.1r2 i must push SYNC button to make it mix correctly each time the new song enters, so then automix has nosense.
Is a very useful function at first time night at the club, so it would be really good for me to make it work.
Any help welcome
Thanks
Any help welcome
Thanks
Posted Fri 01 Dec 06 @ 11:20 pm
please stick to the one post and folks will help you there
but try the match pitch and gain settings if this doesnt work im sure others will post ideas on the mainthread
Posted Fri 01 Dec 06 @ 11:41 pm
Sorry, what do you mean with "stick to the one post ...."?
Posted Sat 02 Dec 06 @ 12:22 am
lol i thought u had posted this elsewhere but it turns out that was some one else with a similar name so pay me no heed
Posted Sat 02 Dec 06 @ 12:23 am
look for the settings
that say pitchmatch choose :always and gain match always
then pick pitch reset on new load :always gain reset :always
Posted Sat 02 Dec 06 @ 12:25 am
No, you are right, but as only you answered, i thought perhaps topic was not clear enough so i decided to repeat post. Sorry for the inconvenience.
I dont fully understand your setting instructions.
Posted Sat 02 Dec 06 @ 12:33 am
a pretty picture :)
for you
for you
Posted Sat 02 Dec 06 @ 10:50 am
Nice work, thanks a lot.
it fits to my config, very strange, mine fixes bpm's but enters out of compass.
I tried to change from bpm config, "Edit Auto Mix" but config changes each song.
it might be a bug.
V.3.4 didnt have it, it entered always in compass.
it might be a bug.
Posted Sat 02 Dec 06 @ 11:05 pm
what settings do you have on the mk2 console control pannel for fading ect?
Posted Sat 02 Dec 06 @ 11:06 pm
i tried to post image but i dont know how.
Posted Sat 02 Dec 06 @ 11:15 pm
www.tinypic.com
to upload image and get bb code :)
Posted Sat 02 Dec 06 @ 11:19 pm
Posted Sat 02 Dec 06 @ 11:36 pm
on the seccond image (tab)
try different tab settings in the drop down menu for the mix curves this might help :)
Posted Sat 02 Dec 06 @ 11:39 pm
ok, i'll test
Posted Sat 02 Dec 06 @ 11:42 pm
kool :)
Posted Sat 02 Dec 06 @ 11:43 pm
Nothing to do.
It automix and gets right BPM but song enters out of compass... is anyone having also this problem?
It didt happen with 3.4
Posted Wed 06 Dec 06 @ 5:17 pm
what settings on main settings do u have?
Posted Wed 06 Dec 06 @ 6:50 pm
