HEY.... JPBOGGIS........ EMERGENCY
i just went into virtualdj......... and my dac3 is not being recognized
it lights up when computer is booted but nothing from it in virtual
I have a gig at Margaritaville... that i may be getting a contract from if I do well on Saturday....HELP PLEASE
Gig is December 2
Gig is December 2
Posted Tue 28 Nov 06 @ 12:17 pm
go to control pannel
and device manager and check that dac shows up
and try a reinstall of dac driver
Posted Tue 28 Nov 06 @ 1:10 pm
Have you activated it in Virtual DJ?
Config -> Remote control, klick enable at "DMC1/DAC2/DAC3"
Just my idea, from one DAC3 user to another...
Posted Tue 28 Nov 06 @ 3:51 pm
Check that the DAC-3 is enabled in remote control as above and the green light is shown to indicate the DAC-3 has been detected.
If the light stays red, check the USB cable (Try another) and USB socket on the DAC-3 (Might be damaged.) Also, try plugging the DAC-3 into another USB port on your computer/laptop.
Posted Tue 28 Nov 06 @ 6:50 pm
