I have the altec Lancing ADA995 Speakers on my PC. (http://support.euro.dell.com/support/edocs/acc/ada995/index.htm) There are 3 wires ont he cable with 3 coloured ends. Green (Front Speakers) Black (Rear Speakers) and Yellow (Sub and Centre). These should match the Analogue Outputs on the hercules, but I have never been able to get the rear speakers to work. The Green cable I plug into channel 1-2 (front) and it works fine with the sub and the front speakers but no matter what I try I cannot get the rear ones to work at all.
If I plug the green into any of the other outputs I get nothing, which says to me that there is no output coming form anything other than chanel 1-2. Is this correct, how can I cahnge it?
I'm wondering if there is a reason this would not work, or if there is a workaround. Can I get a splitter to take the feed from 1-2 and feed it to the rears as well?
Any suggestions appreciated.
Thanks
Thanks
Posted Tue 28 Nov 06 @ 10:35 am
have you selected 4.1 or 7.1 card mode in config
or simple?
or simple?
Posted Tue 28 Nov 06 @ 11:34 am
What Version are you using?
Posted Tue 28 Nov 06 @ 2:22 pm
I have the Mk1 console, I think it is 2.0 but I am also playing with the 4,1 trial but it is the same.
Sorry where exactly do i select 4.1 or 7.1 in Config
Posted Tue 28 Nov 06 @ 5:05 pm
for the 2.0 version , you can't....on 4.1 it should be in the sound config. tab
Posted Tue 28 Nov 06 @ 5:32 pm
