Ok im trying to broadcast through listen2myradio got all my creds right but it keeps telling me encoder error! i have downloaded the lame_enc and tried it and still get that error! can someone plz help me!
Thanks in Advance!
Thanks in Advance!
Posted Sun 26 Nov 06 @ 8:01 pm
send as shoutcast not icecast
which version of vdj are u using?
Posted Sun 26 Nov 06 @ 8:02 pm
i send as shoutcast and im using 4.1
Posted Sun 26 Nov 06 @ 8:10 pm
what is your upload speed ?
do you have a router?
Posted Sun 26 Nov 06 @ 8:34 pm
256kb and yes i have a router
Posted Sun 26 Nov 06 @ 8:38 pm
try a reinstall of vdj
aslo use the latest demo if u dont have it
Posted Sun 26 Nov 06 @ 8:59 pm
i was using 3.2 and upgraded!! and i got the same message on 3.2
Posted Sun 26 Nov 06 @ 9:05 pm
please update to the latest demo
or add your serial
https://virtualdj.com/fusers/modifuser.html
there is no support for cracked users
or add your serial
Posted Sun 26 Nov 06 @ 9:42 pm
im using the demo
Posted Sun 26 Nov 06 @ 9:54 pm
please update to 4.1r2
Posted Sun 26 Nov 06 @ 9:56 pm
thats wat im using
2days into it!
2days into it!
Posted Sun 26 Nov 06 @ 10:09 pm
have you
unblocked the port they gave you in firewall settings
have you reinstalled the lame codec
https://virtualdj.com/forums/59741/General_Discussion/The_Ultimate_Guide_to_Broadcasting_With_Virtual_Dj_).html
for more infos
http://www.free-codecs.com/download/Lame_Encoder.htm
lame codec if u need it again :)
for more infos
Posted Sun 26 Nov 06 @ 10:13 pm
but im broadcasting to an outside server
do i still need to do port fowarding?
Posted Sun 26 Nov 06 @ 10:17 pm
dont worry about that
have u reinstalled the lame codec?
Posted Sun 26 Nov 06 @ 11:20 pm
installed the new codec same prob
so t u saying i still need to do port fowarding?
Posted Mon 27 Nov 06 @ 12:14 am
If you're streaming to another server you won't need port forwarding.
Posted Mon 27 Nov 06 @ 9:23 am
yes just replace the codec port forwarding doesnt matter
Posted Mon 27 Nov 06 @ 10:40 am
aight if found the prob my bitrate was too low! bt its up and running now
doubt u guys listen to DANCEHALL but when our website is up i will drop a link in here for it! THNX!!!!
Posted Mon 27 Nov 06 @ 3:57 pm
good to hear
if u like this product please buy it
Posted Mon 27 Nov 06 @ 4:09 pm
Posted Mon 27 Nov 06 @ 4:35 pm
