hi;
i wantto make my friend to listen to me.im opening broadcast.it gives me for exp this address
http://85.104.202.16:8000/virtualdj.mp3 but no body able to listen to me.when they paste ıt to directly to explorer it says open or save.niether open or save works.when tried to also winamp to add url to paste this link,it says time out.even i was open my 8000 port and foward to my inbound ip but nothing changed:(
can you help me about that?
thanks
thanks
Posted Sun 26 Nov 06 @ 12:11 am
Posted Sun 26 Nov 06 @ 12:17 am
be sure i tried the things.otherwise i ll not write here...
thx for your help any way
Posted Sun 26 Nov 06 @ 2:43 am
what firewall do you have
what os
and who proivides your internet
what model of router?
what os
Posted Sun 26 Nov 06 @ 11:59 am
was tried on xp s orginal firewall and also with bitdefender.and without firewall.
im sure there no problem with my inside firewall becouse in my network other pc were able to listen with my ip.like 192.168.0.2:8000/vitrualdj.mp3
my os xp sp2
internet provider Turktelekom (most idiot one actually in da hole world:( )
i have 2 routers for adsl both i was tired. 1 of them asus AM6010EV-M.connection over from cat5
and dlink dsl-g624t wireless router.both im useing for diffrent lines.i tired on both.
tired with diffrent ports nothing changed.hard firewalls disabled on both routers.
and for example on same pc webcam broadcast program works on same rules.and without problems.
thats the most strange thing.why my ohter programs works which needs port fowards too but virtual dj doesnt:(emule,remoteadmin,activeweb cam.all those programs also i made port thing.
thats all:(i hope u got solution.
my os xp sp2
Posted Sun 26 Nov 06 @ 4:28 pm
a simple fix for this would be to use an external server
such as www.listen2myradio.com - free
aslo consult with your internet provider to see if they have blocked that port some do
i personaly had to have a heated discusion with aol to get it unblocked for me
Posted Sun 26 Nov 06 @ 4:30 pm
I *BELIEVE* that the trial version does not allow broadcasting. If you're not using the trial version then sorry, I dont know why. (just a thought)
Posted Sun 26 Nov 06 @ 7:30 pm
trial is now fully funtional for 20 days
i feel this is more of a router config problem than the software
Posted Sun 26 Nov 06 @ 7:31 pm
Sky,
Thanks. I THOUGHT there were SOME limitations to the trial version... oh well, live and learn.
Posted Sun 26 Nov 06 @ 8:02 pm
so did i lol
but then they decided to make it 20 days full
which is good because it encourages sales
but i fear its easyer to crack
Posted Sun 26 Nov 06 @ 8:35 pm
ok guys ok..thx for everyone.
ı dont know what happens but ı trıed hole nıghlong ı wont work.
but ın mornıng walla.suddenly ıt starts to work.so strange and ı dıdnt change any thıng.even ı dıdnt restart machıne.
any way who cares now ıt works...
best regards....
lets roll the vınlıys
best regards....
Posted Mon 27 Nov 06 @ 4:45 am
glad to hear it works
but if you like this product please buy it
Posted Mon 27 Nov 06 @ 10:41 am
