I have been trying to get the firebox sound card to work.
suttering and clicking occurs while playing videos and or music.
have tried different settings.
Posted Sat 25 Nov 06 @ 11:58 pm
try this
lower your proformance tab
Posted Sun 26 Nov 06 @ 12:23 am
what are your system specs, and do you have the latest driver for the firebox?
I d/led it from their website, and installed it on my lappy, without using the cd that came with it, and it worked fine.
Posted Sun 26 Nov 06 @ 4:42 am
Here is the link to the latest driver for the PreSonus Firebox(left click, and the file d/l box should appear):
http://www.presonus.com/drivers/FireBox_121_Installer.exe
I hope that helps.
I hope that helps.
Posted Sun 26 Nov 06 @ 4:45 am
call or email them for support, they will email you a list of recommended tweaks for your operating system.I have this card it works great since I implemented the suggested optimizations.
Posted Tue 28 Nov 06 @ 7:07 am
