anybody can tell me what must i change in vdj settings to get AUTOSYNC activated when playing automix?
thanx
thanx
Posted Fri 24 Nov 06 @ 3:21 am
on options
choose
Match bpm : Smart
Match Gain : always
choose
Match bpm : Smart
Match Gain : always
Posted Fri 24 Nov 06 @ 10:53 am
doesnt work...songs enter not sync when automix. Any other idea? with 3.4 version worked perfectly
Posted Thu 30 Nov 06 @ 10:28 pm
change it to always on both
Posted Thu 30 Nov 06 @ 11:09 pm
sorry, where?
Posted Thu 30 Nov 06 @ 11:42 pm
Posted Thu 30 Nov 06 @ 11:46 pm
thanks for your support....unfortunately still the same problem.
The entering song doesnt syncs and when new song loads doesnt finds starting cue :(
Posted Fri 01 Dec 06 @ 12:00 am
how bizzar i shall experement
Posted Fri 01 Dec 06 @ 12:01 am
I will thank you.
Is very strange. With VDJ 3.4 version, automix was very smooth and syncronized without changing almost the config.
Posted Fri 01 Dec 06 @ 12:13 am
i found something: Autocue - Always let start with cuepoint not marked but still doesnt syncs
Posted Fri 01 Dec 06 @ 12:27 am
it works for me so im reali confused
does any one esle have any ideas
Posted Fri 01 Dec 06 @ 10:50 am
how bizarre, so when you automix, the entering song syncs ok with no delay?
can you send me your config screenshots? (options and performances, please)
thanks
thanks
Posted Fri 01 Dec 06 @ 11:37 am
