yeh, i wanna know also what does bypass mode allow u to do?
Posted Sun 03 Dec 06 @ 6:08 pm
lets u play real vinyl
Posted Sun 03 Dec 06 @ 6:42 pm
ok, so whats the keyboard shortcut description? I'm looking at the possible shortcuts and the only one I can see that looks possible is "timecode_activate" .... is that the one?
Also when you are just passing through real vinyl what does virtual dj display? Does it show you the beat counter? can you use effects with it?
Posted Sun 03 Dec 06 @ 10:45 pm
i think the bypass no longer works in 4.0, you have to buy 4 y adaters to split the turntable inputs to the mixer and soundcard
Posted Sun 03 Dec 06 @ 10:46 pm
can anyone confirm this? not that i don't believe your or anything - i just hope its not true!
...if it is true are there any plans to bring it back?!?!?
Posted Sun 03 Dec 06 @ 11:50 pm
skyfxl please tell me its not true that u cant use bypass mode pleeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaassssssssssssssssssssssssssssssssssssssssseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee trueeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! please someone conferm if u can or cant use bypass mode in v4.1
Posted Mon 04 Dec 06 @ 1:09 am
the bypass that was in older versions was not good at all, it would pop and have horrible static. The only way to use real vinyl with good results was with y adapters. I am 99% sure the bypass no longer works, i used to have a shortcut just to try it now and again and i was curious when 4.0 came out with the new sound engine that it might have been improved but the shortcut no longer worked. Certainly you can spend $10 on cables and not have to worry about it :)
Posted Mon 04 Dec 06 @ 4:57 pm
well yeah, its easy enough having it working with Y adapters (i've done it today and works ok), but it would be great to be able to have some real time analysis and manipulation of the currenty vinyl playing in VDJ (i.e. bpm, use of effects, looping even?)
Posted Mon 04 Dec 06 @ 10:44 pm
ANY DJ IN LOS ANGELES? CAN HELP ME WITH MY SET UP
Posted Tue 05 Dec 06 @ 12:43 am
