Forum: Old versions
Topic: Vdj freezes when console in - Page: 1
Hi!
My bcd2000 is plugged with the trial version of vdj 4.1, but after maksimum 10 minutes virtual dj freezes. how to solve this ?
Posted Sun 12 Nov 06 @ 12:59 pm
sbangsPRO InfinityMember since 2004
Posted Sun 12 Nov 06 @ 1:01 pm
How dos it work the program?
2.08 ghz
512 mb ram
Posted Sun 12 Nov 06 @ 1:29 pm
basicaly it will tell you all about whats on your computer and more importantly the irq channels
your device is using
if they match with another device this can cause problems
try lowering your proformance tab aslo from quality to fast
preferences > proformances
fast < quality
Posted Sun 12 Nov 06 @ 1:36 pm
Its is on Fast and not quality...
Posted Sun 12 Nov 06 @ 1:42 pm
I found this:
Bus Adapters
Standard Enhanced PCI to USB Host Controller
VIA Rev 5 eller nyere USB-universel værtscontroller (4x)
Multimedia
Behringer BCD2000 V1.0.0.6
Behringer BCD2000WDM V1.0.0.6
Realtek AC'97 Audio for VIA (R) Audio Controller
Posted Sun 12 Nov 06 @ 1:45 pm
do you have wifi?
Posted Sun 12 Nov 06 @ 1:47 pm
IM sorry, but what do's that mean? :)
Posted Sun 12 Nov 06 @ 1:48 pm
If its wireless internet - then no.
Posted Sun 12 Nov 06 @ 1:49 pm
Please help me ! :( - i dont want to buy vdj if it dosn't work.
Posted Sun 12 Nov 06 @ 3:41 pm
Be patient man we're sunday!
Posted Sun 12 Nov 06 @ 4:20 pm
have u run a full defrag on all your files ?
Posted Sun 12 Nov 06 @ 6:09 pm
defrag?
Posted Sun 12 Nov 06 @ 6:30 pm
never mind defrag
the bcd2000 freeze almost only because of IRQ sharing.
This is because the BCD drivers are too sensitive to underbuffer of audio data.
The solution is to disable hardware that you dont use when mixing:
- WiFi
- Lan
- Bluetooth
(all of above use "internal" usb often)
+ CD rom on rare occations (if internal usb mode)
Also, dont run Antivirus, MSN etc when using BCD
its very very sensitive to underbuffer, so you need to make sure it has a constant flow of audio data
Posted Sun 12 Nov 06 @ 6:52 pm
But i use bcd2000 to broadcast with!
Posted Sun 12 Nov 06 @ 8:12 pm
micha3lHome userMember since 2006
THERE IS ONLY ONE SOLUTION TO ALL THE MUSIC STOPPING.
TURN OFF YOUR WiFi CONNECTION!
YOU CAN TURN IT OFF USING THE KEYBOARD USUALLY THE "FUNCTION" BUTTON PLUS ANOTHER ONE. IN SOME TOSHIBA LAPTOPS, THEY'RE IN FRONT OR AT THE SIDE OF YOUR LAPTOP.
JUST REFER TO YOUR MANUAL.
ANOTHER IMPORTANT THING,
DISABLE YOUR WIRELESS NETWORK CONNECTIONS UNDER CONTROL PANEL->NETWORK CONNECTIONS.
MAKE SURE IT'S DISABLED.
NOW YOU CAN FOLLOW julio's INSTRUCTIONS IN HIS BLOG.
I dont have any wifi's - and nothing in usb except Bcd2000..
Posted Sun 12 Nov 06 @ 8:15 pm
there must be somthing conflicting with it
did you check the channels of irq?
Posted Sun 12 Nov 06 @ 8:25 pm
Hmm it seems to be away now.. I will return if it gets back. Thanks for the answers!
Posted Sun 12 Nov 06 @ 8:34 pm
okies :)
if u like the software please buy it:)
Posted Sun 12 Nov 06 @ 8:37 pm
80%
