I'm putting together a rackmount pc What is a great soundcard to put internal?
Posted Mon 06 Nov 06 @ 9:27 pm
Posted Mon 06 Nov 06 @ 9:35 pm
Just get external one and you can't fail. If it will be in rack, all yout connectors will be out of rack, so at the back perhaps. So you will need to plug them out of rack and it will be strange to see. Get external one, plug it to usb port that can be mounted into rack and you can hide the unit and all cables.
Posted Mon 06 Nov 06 @ 10:52 pm
Yeh good idea :)
Posted Mon 06 Nov 06 @ 10:58 pm
... and sound cards can be maya44 USB or U46DJ :)
Posted Mon 06 Nov 06 @ 11:01 pm
isnt the maya discontinued :(?
theres now personous firebox on the market 2
Posted Mon 06 Nov 06 @ 11:04 pm
i saw there are still some pieces in some shops. i have it and love it ;)
Posted Mon 06 Nov 06 @ 11:16 pm
The only problem is if they don't make it, is it going to be as easy to get support/repair for it?
Posted Tue 07 Nov 06 @ 12:05 am
they will have to still support it
for the lengh of its warenty
Posted Tue 07 Nov 06 @ 9:30 am
Well.. support will allways be there as long as manufacturer exist. And i really doubt about repairing such a thing. If it is still in guarantee, you will get new one (manufacturer allways keep some products for backup), if it is not under guarantee, you simply buy new.
After all, U46DJ is great.
