Hi All,
Yesterday I bought the Virtual Dj Pro 4 version, and when using the software there is a (very) disturbing sound that occurs when using the eq buttons of my Hercules MkII. It's like a disturbing signal that overpeaks the normal audio. When just using the Mk2/Mp3 version of the Virtual Dj software (which was included with the Hercules Dj console I bought), this problem does not occur.
Is this problem known? Are there any tricks to solve the issue?
Thx for your advise, I hope you can help me out.
Cheers
Jan
Cheers
Jan
Posted Mon 30 Oct 06 @ 11:21 pm
try dropping the proformance slider to fast
preferences > proformance
Posted Mon 30 Oct 06 @ 11:23 pm
Hi skyfxl,
It was standard on 'fast', so I raised it in trying to make a difference, however no joy.
thx anyway
jan
thx anyway
jan
Posted Mon 30 Oct 06 @ 11:27 pm
il do some research
any one esle got any ideas?
Posted Mon 30 Oct 06 @ 11:36 pm
Gotcha!
Performance - soundcard - uncheck 'Safe Mode'.
Thx anyway
cheers
Thx anyway
cheers
Posted Tue 31 Oct 06 @ 6:01 pm
kool :)
Posted Tue 31 Oct 06 @ 6:17 pm
