Hello
I'm having trouble with how the automix works and would like your help
Can you please tell me how to load music list so that vdj will mix automatically.
Do I load my 1st 2 songs from my songlist under the search icon or from the right hand side where I add my song selection?
I thought that once I load my first 2 songs then vdj would automix all of my additional selections.
Pls help
Thanks
Pls help
Thanks
Posted Mon 30 Oct 06 @ 12:05 am
create a playlist on side window
then press the magic wand to automix
this will load them for u :)
Posted Mon 30 Oct 06 @ 12:08 am
Can I still add additional songs on the right after the automix is started or do I need to create a playlist then then prompt the automix?
Posted Mon 30 Oct 06 @ 12:24 am
u can add and add and add
for ever lol
for ever lol
Posted Mon 30 Oct 06 @ 12:44 am
thanks for the info.
As there is a newer version for virtual dj, what is the canadian cost for the program?
Posted Mon 30 Oct 06 @ 3:43 am
You can even move them up and down the list - if somebody asks for a song and it's somewhere at the bottom, riight-click and move it up - or move another track down the list in the same way.
I did a wedding gig last Saturday, using Virtual DJ. It worked for about half-an-hour, then the tracks slowed down - an effect similar to a child giving a piggy-back to a Japanese Sumo wrestler - in the end, I just used Windows Media Player, with the crossfader on. Haven't downloaded the new update yet - I hope that, when I do, it will fix the problem.
Posted Mon 30 Oct 06 @ 10:54 am
299 U.S. dollars = 335.6873 Canadian dollars :)
Posted Mon 30 Oct 06 @ 11:46 am
