I notice since the new audio engine after v3.4, that here has been audio interference when controlling VDJ with a mouse.
What happens is I could be playing a track on 1 of decks and setting the next track up on the other. As the bass is playing on current deck you could do a one of the following. Spin the other deck in position, adjust the volume for the deck or move the slider into starting position.
you will hear low level interference like a grumbling sound faint I know sound funny but as I spin the deck into position you can hear it. I have a 5.1 sound card setup.
Great work by the way guys, I also just tried that tractor 3 and this beats it hands down keep up good work.
Posted Wed 25 Oct 06 @ 1:46 pm
You should set lower setting in the Performances tab, your PC is not powerfull enough for the current setting. Try also to diselect safemode and overclock and turn off keylock and try than.
Posted Wed 25 Oct 06 @ 5:37 pm
you can find that in
main settings > proformances
move the slider closer to fast in small steps until the problem stops
, glad u like it i personaly agree much better than tracktor!
Posted Fri 27 Oct 06 @ 3:56 am
