i know the "Evolution" X-Session midi controller has been discussed here for a while
also know a few are using it in their setups
i did a recent search again and ....
http://www.m-audio.com/products/en_us/XSessionPro-main.html
is this a new one or ...
it has pretty much all you need except the wheels
does anybody have any more details on it ?
cheers,
matt
cheers,
matt
Posted Tue 24 Oct 06 @ 6:09 am
Already posted - https://virtualdj.com/forums/58368/Hardware_Technical_Support/M-Audio_Releases_X-Session_Pro.html
Next time do a search in this forum.
Posted Tue 24 Oct 06 @ 6:28 am
oooops
i knew i've been missing something
i did a search but not in the h/w section, sorry
Posted Tue 24 Oct 06 @ 6:47 am
maybe you could use the cross fader for the video fader, and mix your tracks using the faders? thats what I would do. No sound card is a prob, but as far as a portable controller, this might do the trick! But you are still gonna have to use a main mixer to cue each channel....think of this controller like a DAC, only one step above because you can control volume too. I wonder, is "instant start" a viable idea using this controller, or will there be some latency in starting the track?
Posted Tue 24 Oct 06 @ 7:04 am
