try reinstalling the console :)
Posted Tue 09 Jan 07 @ 6:59 pm
Just set the latency in VDJ to auto when running BCD2000..
(after shutting down Wifi, lan and bluetooth)
Posted Wed 10 Jan 07 @ 1:09 am
I've had this same problem
Posted Wed 10 Jan 07 @ 2:03 am
I've tryed several configs but problem still remains
Posted Wed 10 Jan 07 @ 10:24 am
Tried reinstalling the bcd driver but it it still stopping
any further suggestions ?
Posted Wed 10 Jan 07 @ 3:41 pm
did you have any conflicts on your device list?
Posted Wed 10 Jan 07 @ 3:45 pm
Can you just run through how I can check this ?
Rick
Rick
Posted Wed 17 Jan 07 @ 2:18 pm
Posted Wed 17 Jan 07 @ 2:53 pm
Sorry skyfxl I didnt know what you meant yes I have checked this & to the best of my knowledge there are no conflicts. Is there anyplace I can send you a screenshot to show you ?
Posted Tue 23 Jan 07 @ 11:52 am
here is a little solution, but enough to work...unistall VDJ, run the Virtual Dj Registry key removal https://virtualdj.com/addons/view.html?type=tool and then reinstall VDJ and fallow the instrucctions on my block https://virtualdj.com/blog/juliocqb/?category=2,..
Let me know if this worked...
Regards
Dj Quintana
Regards
Dj Quintana
Posted Tue 23 Jan 07 @ 3:43 pm
Note for notebook users: If you encounter problems operating the BCD2000 from your system, please disable the following settings:
In the Device Manager (right click on My Computer> Manage> Device Manager), click option “Batteries” > disable Microsoft ACPI-Com pliant Control Method Battery.
In the USB Controller, do the following for each single USB Root Hub: Right click > Properties > Power management > disable the option “Allow the computer to turn off this device to save power”.
Restart Windows XP. Now the system performance of your computer should be more stable..
And don t forget to disable the Ethernet card ….
this works for me ...
Posted Thu 25 Jan 07 @ 9:17 pm
it's three months by now that my bcd remains in its box waiting for a solution from behringer
Posted Fri 26 Jan 07 @ 9:44 pm
Dj kike
I had the same problems and that was the solution, unpack your BCD and give it a try …..
Posted Fri 26 Jan 07 @ 11:48 pm
a lot of laptops come preinstalled with software that controls power settings and also wireless lan settings, maybe they are also a problem with the bcd2000. i know with my toshiba laptop, i have fallen short because of this preinstalled software so i got rid of it and now, no problems! something to think about!
Posted Mon 29 Jan 07 @ 5:56 pm
I GOT AN IDEA.... IT WORKS A LITTLE WITH FREEZING I HAVE SIMILAR PROBLEMS BUT I USE NUMARK CUE (SAME THING) IF YOU PRESS CTRL ALT DEL IT WILL BRING THE TASK MANAGER UP. IF YOU RIGHT CLICK CUE OR VDJ AND GIVE IT HIGH PRIORITY YOUR CPU WILL FOCUS ON THE VDJ PROGRAM. I ALSO RUN AN IBM P4m 2.4 WITH 512 RAM AND I STILL GOT SMALL ISSUES IT SKIPS THROUGH SONGS AND DELETES THEM FROM MY PLAY LIST BUT THIS HELPED ALOT!!!
Posted Thu 22 Mar 07 @ 3:28 am
Nice tip :)
Posted Thu 22 Mar 07 @ 5:43 pm
i tried but my notebook still freezes vdj if i use bcd2000 when i must play at vdj radio.... can you imagine suddenly stop music when 500 people is dancing on the floor (i play radio sessions live when working at the club)... i hope you dont have that experience.
I really desire this freezing problem to be resolved for bcd2000, is a nice controller. Also there's an unsolved split problem for headphones.
Posted Mon 26 Mar 07 @ 7:35 pm
same problem, almost returning the product to the factory, tryied EVERYTHING, there's something you didn't mention, the behringer site has a patch for Intel motherboards, something like that. It might be a solution for some, for me it wasn't. even on Mac it freezes the traktor, using as MIDI controller (it doesn't work as sound card on macs, only bcd 3000 does). Does anybody know it bcd 3000 has the same problems!!??
Posted Fri 25 May 07 @ 3:34 pm
i finally decided to return my bcd2000.
bcd3000 looks the same though i didnt try but ill not take the risk for a new deceive
Posted Fri 25 May 07 @ 11:51 pm
According to behringer, is suppouse that bcd3000 is the replacement for bcd2000 that had conflicts with several chipset, although externaly are quite similar, bcd3000 has changed inside and modified the chip as well as some other pieces.
Posted Sat 26 May 07 @ 3:56 pm
