ever since I upgraded to 4.1 my sound effects, video effects, transitions and sonique animations won't work. Am I doing something worng or do I have to change something?
It's happened on 2 diffrent computers that I own.
Posted Mon 09 Oct 06 @ 7:55 am
You may have to set them all up again, as th update could have reset everything back to default.
IE Sonique needs a directory
So does Slideshow ect.
Posted Tue 10 Oct 06 @ 12:40 pm
OK I found the problem; my videos will not work correctly when “Use hardware acceleration” is enabled and my effects won’t work when it is disabled.
Can anyone explain this? and what I can do to fix it?
Posted Wed 11 Oct 06 @ 4:32 am
what kind of video card is it? did you get the august 2006 dx drivers?
Posted Wed 11 Oct 06 @ 4:34 am
NVIDIA GeForce Go7300 with 512mb ram
Posted Wed 11 Oct 06 @ 4:49 am
I can get them both to work together but the videos will stop and studder when ever I start up a new video, untill I load a new video in replacment of the one I was just playing. then the video will play correct
Posted Wed 11 Oct 06 @ 4:51 am
WTF. upgraded to 4.1 now I can't preview using the Hercules DJ console. Output set for channel 1&2 and preview 3&4 as it was before. Now when I put it on split I only hear the current song not the preview even on the deck a and b switch also. This sucks big time. Hope there is a solution for this.
Posted Wed 11 Oct 06 @ 5:01 am
theres a fix in the general forum
Posted Wed 11 Oct 06 @ 5:04 am
I found that it's a bug in my Video Card, I think I found the fix on another page.
Thanks!
Thanks!
Posted Wed 11 Oct 06 @ 7:41 am
Hope it works out!!!
Posted Wed 11 Oct 06 @ 7:44 am
For the NVIDIA GeForce Go 7300 Video Card;
you have to buy the "NVIDIA Purevideo Decoder"
from www.NVIDIA.Com.
Then Change the Video Codecs in VDJ Config to the
"Windows MediaPlayer Video Decoder"
If you don't have the "NVIDIA Purevideo Decoder" the
"Windows MediaPlayer Video Decoder" will freeze and lock-up.
The "NVIDIA Purevideo Decoder" helps MediaPlayer run MPEG-2 you need to play Vob files
Posted Wed 11 Oct 06 @ 10:29 am
The moral of this story :-
Buy ATI lol
Buy ATI lol
Posted Wed 11 Oct 06 @ 11:39 am
I had the same issue with the hercules. Updated and now no preview. AHHHHHH
Irritating. Was on my pc for hours trying to figure it out.
Posted Wed 11 Oct 06 @ 9:17 pm
After some testing on an external monitor and some help from a Toshiba tech I found that the For the
The "NVIDIA Purevideo Decoder" only helps on the main screen and not on the 2 monitor.
I'm gonna see If toshiba has a fix for this.
STAY AWAY FROM For the NVIDIA GeForce Go 7300 & 7400 Video Card!
I have an 64 MB ATI on an 2 year old Dell that blowes the NVIDIA card out of the water!
Posted Fri 13 Oct 06 @ 6:59 am
It is the driver problem not a graphic card, altough I wouldn't recommend them for video use. 7600 Gs or Gt is the way to go.
Posted Fri 13 Oct 06 @ 11:34 am
