Did anyone notice the distortion on VDJ 4.0 when you use the crossfader or any knobs on the unit.
Can someone explain ?
Thank You,
TH.
Thank You,
TH.
Posted Sun 08 Oct 06 @ 2:43 am
Are you talking about Hercules MK2?
Posted Sun 08 Oct 06 @ 6:26 am
I believe he is talking about with the mouse and I had that problem, but if you put your setting to safe mode that should disappear. Try playing with your settings til you find the happy medium.
If you ARE using the MK2 DO NOT USE safe mode as it causes problems.
Posted Sun 08 Oct 06 @ 7:11 am
