Virtual DJ connect to BCD 2000. Can you add this option to Virtual DJ 4.0 where you have a set up for BCD2000 to just connect the hardware and make it work?
Posted Tue 03 Oct 06 @ 4:25 pm
Dev tem is working on it and probably will be incorporate on the new update.
regards
dj quintana
regards
dj quintana
Posted Tue 03 Oct 06 @ 4:29 pm
there is a solution to connect bcd to Virtual DJ, loook this blogs:
https://virtualdj.com/blog/moramax/
https://virtualdj.com/blog/juliocqb/
Posted Wed 04 Oct 06 @ 8:02 am
Download new 4.1 version that is currently available
Posted Mon 09 Oct 06 @ 2:35 pm
Can someone who has BCD2000 tell us how the new version (4.1) is working?
Posted Mon 09 Oct 06 @ 7:41 pm
Asio drivers are more stable at leats for me, wdm is now working with headphones, leds are working as well, the only thing didn't like is that cue_stop is working as hotcue.
Posted Mon 09 Oct 06 @ 8:11 pm
Nice to hear, I will recive MK2 in a few days (I hope), and than will look forward to get BCD to test and see what's better for me. Thanks!
Posted Mon 09 Oct 06 @ 8:56 pm
VDJ 4.1 and BCD2000 works nicely together now. Just need the ability to change some of the mappings for the controller and it will be awesome. The system is more stable than it was before.
Posted Mon 09 Oct 06 @ 11:13 pm
mapper is currently being made, and will hopefully be released real soon :)
Posted Mon 09 Oct 06 @ 11:14 pm
Good news Norway ;) , mine MK2 was bought but is still in Austria, now I wait for the damn Bus to deliver it here... damn country, I have to move :))))
Posted Tue 10 Oct 06 @ 12:09 pm
lol, mine BCD2000 arrived this morning by UPS.
I couldn't sleep when I yesterday found 4.1 update that supports BCD.
And now after playing with BCD at work for whole day, I'll have to work overtime tommorow :-)
It is working fine, except some functions (mic, phones selection...)
looking forward for the mapper. Kudos do devteam and all that helped to make 4.1 possible.
Posted Tue 10 Oct 06 @ 4:51 pm
I connected my new bcd 200. No matter what option that I have used. vtDJ and bcd 2000 would work for about 2 minutes and no sound after that. VT 4.1 did solve the laptop being frozen but now the sound card ifs being frozen or being overloaded. My pc is an Inspiron 5100 with a 1gb memory, 2.8 processor. I don't know what to do anymore!
Posted Tue 10 Oct 06 @ 5:42 pm
What driver versions you have and What settings have you configured in the performance tab? Do you have a wireless card maybe try disabling that since it may be affecting the BCD2000 drivers
Posted Tue 10 Oct 06 @ 5:46 pm
The BCD2000 asio drivers will freeze if they run out of audio buffer (Behringers fault, and hopefully they will release new drivers).
Depending on how fast your PC is, and the state of IRQ sharing at your PC, try this:
- set performance slider in VDJ at the "fastest" preset. Then increase it step by step until you get problems. When problem occur, step on step back.. .and you have found your optimal setting ;)
- Also, try AUTO for latency in VDJ....
If all fails, chances are huge that your USB ports share IRQ with other intenstive devices, and that the interupt from those devices (on same IRQ as your BCD2000), makes the audio buffer run out = FREEZE
Also, if you have installed some midi Yoke (or JOKE! lol), before 4.1, try a clean install of VDJ...
Uninstall VDJ, delete registry entries, reboot, and reinstall VDJ.
Hope that helps ;)
Posted Tue 10 Oct 06 @ 6:07 pm
Microphone problem ! I bought a BCD2000 and I tried it with VDJ 4.1 trial version. Everything works fine but I can't use my mic on BCD2000. I connected my mic to "mic XLR" on the back panel of my BCD2000. On Air, Talkover and Clip LEDS are flashing when I talk into my mic but no sound. I use these setting : Behringer Control Panel in "Advanced mode" and VDJ4.1 trial setting :"Cofing - Remote Control - BCD2000 enable". Is this a setting problem or only my trial version problem ? Everybody can use mic with BCD2000 ? Please help. Thank you.
Posted Mon 04 Dec 06 @ 8:08 am
Mic doesn't work in VDJ using BCD-2000 yet...
Posted Mon 04 Dec 06 @ 8:11 am
hi.. are you using a laptop?
Posted Mon 04 Dec 06 @ 8:14 am
Hi ! Yes I using a laptop. AMD 1,87 Ghz/512MB. Any idea ?
Posted Mon 04 Dec 06 @ 8:50 am
Unfortunately no.. I’m still deciding if I should buy the BCD2000.. I got some good feedback for PC users….
https://virtualdj.com/forums/60745/Hardware_Technical_Support/____BCD2000_Desktop_Users_____FEEDBACK.html
WirelessDJ Has Doing some heavy investigating on the BCD2000.. He should beable to help…
Good luck
Good luck
Posted Mon 04 Dec 06 @ 9:11 am
Hi All,
Could someone who has been using VDj 4.1 and BCD2000 let me know whether sound starts crackling/breaking up in between as it happens with the Xylio Dj Software...
Thanks,
Tomy
Thanks,
Tomy
Posted Tue 05 Dec 06 @ 10:42 am
