I was wandering if anyone has experinced the same problem with the samples in V4...When recording a mix as soon as you start using a sample the mix skips when you play it back. V3.4 doesn't do it and only V4 I experinced that it does? Any suggestions?
There are no other programs running while V4 is...no Antivirus or Wireless internet
The Laptop is a dell ispiron...1 gig of memory, duo processor...
Posted Tue 26 Sep 06 @ 8:43 pm
try lowering your profromance slider to more reactivity
Posted Tue 26 Sep 06 @ 11:17 pm
