Hello,
I have this problem:
Some outputs does not work, output 3 + 4 and output 5 + 6 dont work,
how I must integrate these. On output1 + 2 I have me PC speakers.
On output 3 + 4 I want my Receiver.
I heard that it can make something with the driver for 44.1 and 48 Khz ?
How can I see that which I do use ?
I use this drivers : U45DJ v1.0.16 a try olso v1.0.14 bud no effect same problem !
My system is:
Mainbord: ASUS P4SD-LA
Chipset: i865P/PE/G/i848P
Pentium 4 - 2,8 Ghz
1024 DDR Memory
My system is:
Pentium 4 - 2,8 Ghz
1024 DDR Memory
Posted Thu 14 Sep 06 @ 6:36 pm
do you get ASIO error "not enough channels? or if you dont try moving the volume slider all the way down, and then back up. I was having no volume on mine and once i moved the slider i then could hear the sound. 1.014 would not work at all for me, i use 1.016
Posted Thu 14 Sep 06 @ 7:48 pm
No ASIO error, and when I moving the volume slider all the way down, and then back up
nothing happen no sound !
When I the cable of the Receicer in output 1 + 2 stops these works, But the outputs 3 + 4 and 5 + 6 are not working ?
and for output 1 + 2 I use my PC Speakers
I think that they are Disebled, and must on Enebled but how ????
Posted Thu 14 Sep 06 @ 7:59 pm
I have a U46DJ connected... and it tells me that I have an ASIO error with not enough channels... what am I not connecting?? What needs to connect to the computer from the U46 other than the USB? And where would it go into? Is there a schematic for it anywhere??
Posted Fri 15 Sep 06 @ 3:31 am
Then you must make just your own Topic.
This has nothing to do with my problem !
And u are a "NO LICENSE USER" why you do not put your "SERIAL NUMBER" in your profile ?
Posted Fri 15 Sep 06 @ 8:32 am
Trial Versions are limited, with only output for the main and Input for only one Tcv or Tccd
Posted Fri 15 Sep 06 @ 8:49 am
I heard that I in VirtualDJ the ouputs must assign, of the ESI U46D
How do I this ?
How do I this ?
Posted Fri 15 Sep 06 @ 10:53 am
How do I this ?
How do I this ?
are you using 4.0 or 3.4?
Posted Fri 15 Sep 06 @ 11:27 am
I using VirtualDJ 4.0
Posted Fri 15 Sep 06 @ 11:48 am
Okay, how I have to set my Output config in Virtual DJ 4.0 in Output settings to hear output 1 + 2 & 3 + 4 on Master ???
Posted Fri 15 Sep 06 @ 5:28 pm
are you gonna be using timecode?
Posted Fri 15 Sep 06 @ 7:12 pm
No maby later but not on this time
Posted Fri 15 Sep 06 @ 8:27 pm
Everting is working now ;)
only I want to no this:
How I have to set my Output config in Virtual DJ 4.0 in Output settings to hear output 1 + 2 & 3 + 4 on Master ???
And my Mic is not yet working ?
Posted Fri 15 Sep 06 @ 9:51 pm
