Make a skin where the outside of the record scratches (black groove part) and the inside of the record (red part) speeds up or slows down the song (for manual beat matching)? Or is one out there already? Might be cool if you only have a mouse rather than switching back and forth.
Posted Wed 06 Sep 06 @ 4:30 am
anything is possible , with a few clipmask, you can get better help if you post this in the skin forum
Posted Wed 06 Sep 06 @ 5:13 am
Mixstation SV_04 does this but I couldn't get it to install with v4 and was too lazy to figure out how to extract the file manually. IMO all skins need to have this feature, where the middle part of the record allows for finer adjustments as it's makes your mix much more transparent.
Posted Wed 06 Sep 06 @ 5:17 am
theres an update already available, compatible with version 4
Posted Wed 06 Sep 06 @ 5:18 am
