Hi,
I've updated my skin in order to use the key_offset feature (key_lock was already supported).
So I've added one slider per deck for the action key_lock
It works great.
However I've noticed that if I disable key_lock and pitch up (so I'm changing the key) my key_offset sliders are not updated.
Is it normal? Or I misunderstood the purpose of the action key_offset?
Thanks
Pier
It works great.
Thanks
Pier
Posted Sun 03 Sep 06 @ 11:14 pm
i would love to see that! i dont know why key could not have been added as a slider in the normal skins if key offset is an action.
dont know about the issue you speak of tho. maybe someone from the skins forum can help
Posted Mon 04 Sep 06 @ 1:40 am
Hi
That's nothing special.... is just cdj700s (fruity) cleaned and optimized for my needs... plus two sliders.
maybe they thought different ....
Thanks
Pier
Quote :
Thanks
Pier
Posted Mon 04 Sep 06 @ 12:12 pm
