Coould someone give me a decent explaination of what "Smart " icon means on some new V4 skins near the loops section?
I understand pitch and the new lock functions, but don't quite get this in the loop section.
Thanks,
Sorry for being dense.
Thanks,
Posted Tue 29 Aug 06 @ 7:45 pm
Smart is for smartlooping as it was in 3.4, it stays sync on the beat no matter when you press it. When you turn it off, you can make your own custom loop, if you don't wanna sync loop on beat, like on cd players.
Posted Tue 29 Aug 06 @ 8:31 pm
Why can't i take smart loop off.. even tho i have it turn off on the settings
Posted Tue 02 May 17 @ 3:58 am
This is a VERY old thread about VDJ4, but I assume you are using a newer version
You turn it on and off on the little dot below the pitch
Then you probably need to use manual loop in and out, since clicking a loop bar number (like 2, 4, 8 bars) will be smart looping all in itself
Here is an example
Posted Tue 02 May 17 @ 5:12 am
Here is an example
Here is an example
but I never had to do that.. I do have the new version and I disable the smart look and it was fine .. but it seem to turn on again ..
Posted Tue 02 May 17 @ 5:18 pm
