I'm planning to get a 2 x Numark TT1625 coz it's cheap.
Is it compatible with Timecoded Vinyls? And does it work in VirtualDJ?
Another question, how do I plug the turntables to my computer? What hardware do I need?
Posted Fri 25 Aug 06 @ 10:15 pm
yes it will work time coded vinyls and u need a usb soundcard such as u46 dj u can find them on ebay about 200 dollars hope that helped u a lot.
i try to help as many people as i can so therefroe mylevel should go up to experianced pro user lol what do u think?
Posted Thu 23 Nov 06 @ 4:12 pm
thats the spirit lol
yes u46 dj you can hook it up
by putting right deck into input channel 1 on card
and
left into 2
or you could buy a mk2 dj console
and use that as your mixer and card which is easyer :)
and
left into 2
Posted Thu 23 Nov 06 @ 4:46 pm
this is how to set up the table to the cpu (except where theres a maya 44usb u will have the u46dj-cause the maya is being made anymore)
hope this help:
https://virtualdj.com/support/VirtualDJ%203%20-%20Advanced%20ASIO%20configuration.pdf
hope this help:
Posted Thu 23 Nov 06 @ 4:50 pm
LOL
That was one dumb question...
This is so old.
I already know how to hoo up TCVs.
Now, i just want to know if the NUMARK 1625 are REALLY WORTH IT.
I do scratching sometimes.
Is the torque for this TT worth it or is it too weak?
This is so old.
Posted Thu 23 Nov 06 @ 4:58 pm
yes the torque is worth every penny. its better than technics i think thats just openion!
Posted Thu 23 Nov 06 @ 5:12 pm
