someone who speaks english wrote it this time!
the wording of the licence aggreement is stil off tho, did you know you can abuse the program as much as you want as long as you dont 'reduce it to a less than human precieveable form' or something. what does that mean, in case i need to exaplin the code to a monkey, this prevents me from doing that?
Posted Sun 01 Oct 06 @ 3:00 am
i cant seem to get the suggestion box to work at all in v4.0 I had no problems with it in v3.4 I havent seen any option to turn it on or off in v4 but maybe i overlooked it. Is anyone else having this same issue or does anyone have any suggestions that might help fix this problem?
Posted Mon 02 Oct 06 @ 11:47 pm
think it might need playlists to be saved (not default in 4.0)
So, search the general forum for "Registry tool" , and use that tool to enable playlist save.. :)
Posted Tue 03 Oct 06 @ 12:09 am
Dj_GIORGIO forever
Posted Sat 07 Oct 06 @ 12:40 am
hello there im looking to buy this vdj does any one know whats the real price? and where to get it cause im in the Los Angeles Ca. thank you
Posted Sat 07 Oct 06 @ 9:29 am
You can see for yourself the price here: http://www.virtualdj.com/purchase/
Posted Sat 07 Oct 06 @ 11:42 am
RIGHT ON!!!
Posted Thu 12 Oct 06 @ 2:32 am
I have vdj on my desktop workstation to practice with. My gig computer is kept pristine, never been on the internet. I put ver 4.0 on it and it says "invalid version of Directx. please install at least DirectX v9.0c. from microsoft's website. I've tried to download it to the workstation and then copy it over, no luck, any ideas?
Posted Thu 12 Oct 06 @ 5:31 am
Is this what you downloaded?
http://www.microsoft.com/downloads/details.aspx?FamilyId=013C0F78-3C9B-44DC-B8BE-46783BCAC3CB&displaylang=en
If you were at the webinstaller and downloaded it then that's why it didn't work.
Download from the above link, it is the ReDistribution package which is the complete 55Mb package.
Hope this helps,
cstoll
EDIT**
FYI Microsoft updated DX again, it is now Oct2006 Redist version, NO LONGER Aug 2006.
Hope this helps,
cstoll
EDIT**
Posted Thu 12 Oct 06 @ 5:36 am
Yes! that did it. Thanks.
earthman
earthman
Posted Thu 12 Oct 06 @ 6:59 am
This topic should be changed into 4.x.
Posted Thu 12 Oct 06 @ 1:46 pm
