Ask e-service to give you 3.4 installation file again. Just deinstall V4 and install 3.4 again but I don't now if you can use database.xml, it cannot be used from V4 to 3.4, just reverse way. If you transfered your old database from 3.4 to V4, it should be still there in V4 folder, the one without your Windows login name. Backup both just to be sure, if you want to go back to V4 someday.
Posted Sun 24 Sep 06 @ 7:10 am
what does it matter what soundcard I have? I had 3.4 with timestretch off.....it worked fine. Now I do an "upgrade" and my computer is skipping like crazy. I am getting a RAM upgrade soon......could 512 RAM just not be enough realistically here?
I think you should recommend 1 gig of RAM
Posted Sun 24 Sep 06 @ 7:23 am
I have 512mb ram and it is working fine (audio only). But 1Gb will be better for sure.
Posted Sun 24 Sep 06 @ 8:09 am
jrruss-
If you read some of the forums, you'll see that your skipping problem can be easily fixed by making adjustments under the performance tab.
Posted Sun 24 Sep 06 @ 3:51 pm
No, I did those adjustments and it is still skipping and slowing down like crazy....I even went through and did some of the recommended performance tuning on this board. Virtual DJ is still a massive resource hog even though i love it. I really am convinced its the RAM. My computer often says (low virtual memory).
Posted Sun 24 Sep 06 @ 6:25 pm
That will do it! See if you can change your VM settings.
Posted Sun 24 Sep 06 @ 9:44 pm
anyone a idea how to download some skins without being a pro here?
Posted Sun 24 Sep 06 @ 11:36 pm
You can download some of the skins for the others, please buy the software.
@jrrusse1
It must been your virtual memory is fixed to a small amount, change it to 800Mb both values and restart.
@jrrusse1
Posted Sun 24 Sep 06 @ 11:44 pm
@jrrusse1, do you load big files ? dont
For 512 ram set the maxload in options to 15min and set a permanent swap file as dj alf advised.
btw, i have 512 too in my mobile system and working fine, but no bells and whistles in this system..
Posted Sun 24 Sep 06 @ 11:54 pm
Thanks everyone for the ideas...I will try them all. I LOVE Virtual DJ and have used it for two years now....I was just having no problems at all in 3.4 with timestretch turned off....now when i upgraded there were problems. I was a little taken aback..you know? 4.0 was acting like the previous versions did on my computer with timestretch.
That being said....so there is no way to deactivate timestretch now????
.....this is the best pure DJing platform out there....bar none. If you make it work for you it can work wonders! I hope I am not coming off negative about VDJ
Posted Mon 25 Sep 06 @ 3:25 am
You can turn off timestretch by turning off "Keylock" function (just below pitch fader).
Posted Mon 25 Sep 06 @ 3:50 am
To quote my own post, seems you missed it ...
apopsis wrote :
Master tempo can be enabled/disabled on skin now, its "keylock"
If you want 3.4 functionallity just use the 3.4 default skin.
Posted Mon 25 Sep 06 @ 4:45 am
i turned it off.......seems better immediately
I think timestretch was it all along.....makes the song sound like it is "drunk" or slow....skipping and just awful
one timestretch is off it sounds great!!!!!!!!! in the meantime i optimized my computer in a 100 other ways that werent the problem LOL
Posted Mon 25 Sep 06 @ 7:12 am
Glad to hear that is now ok ;)
You can use timestretch and the sound can be good, you can set it in Performance tab, but you need powerfull machine for that.
Posted Mon 25 Sep 06 @ 2:50 pm
V4 rocks
nothing more to say lol
Posted Mon 25 Sep 06 @ 2:56 pm
LOL yes indeed ;)
Posted Mon 25 Sep 06 @ 6:20 pm
VDJ puts tons of cash in my pocket by letting me do things I could never do before.
karaoke = big money
photo slide shows = big money
video = big money
I Love it!
karaoke = big money
video = big money
I Love it!
Posted Mon 25 Sep 06 @ 6:24 pm
Anyone have an extra copy of the timecode cd rip? I'm not to good at burning copies.... Thanks
Posted Wed 27 Sep 06 @ 6:29 am
Manual is available here :)
Posted Thu 28 Sep 06 @ 7:04 pm
good!!!!
Posted Sat 30 Sep 06 @ 1:17 am
