Topic: NEW BPM Detection Software - Page: 4
how big is the file ????
when i download it it says 8.9kb and when u run it u get an error
is this what u were talking about ???
Yeap thats what I get...
congrats NAWTBOY
good work
Ok I can host the file but I need it to be sent to me...If anyone has it and it works send it to djhomeboy@virtualdj.com
smokey187:
you need the Microsoft .Net Framework for the file to run. otherwise wou will get an error.
you can download this in the windows update under the recomended updates section. i think is about 13.7 mb
Thxs...
thanx
hey there are alot of updates
what should i be looking for
Microsoft .net framework.....AND ALL UR UPDATES LOL !
found it 23megs
DJ SpeedLand:
you can use and modify the php script. it's gpl license.
I am currently running the mixmeister software on all 6000+ songs I have, I am sure this will take a while. How long should it take for the little app u made to update the database ?
i tried doing it for 50 songs or so it says wrtiting txt file and thats it nothing happens i think theres somthing wrong with it
but the mixmiester thing will take quite a while
Yes but if you read the disclaimer when running it says that it may appear as though its hung up but in fact its still working....Thats why I asked about how long?
Actually I didn't change the disclaimer, but it shouldn't freeze: it uses a 2nd thread to update the database. I can't tell you how long it should take (because the computer I have here only has about 100 mp3's -- it takes a few seconds for 100 mp3's on my celeron 600 w/ 128mb ram lol).
I just found an error in the display (no bug for the database, only a HUGE slowdown). I updated the file, and everybody should redownload it.
This program requires the .NET Framework to run, that's why some of you might get an error trying to run it if you don't have the .NET Framework.
macourteau
P.S.: congratulations NAWTBOY on your new status :)
@DJ Homeboy: I sent you the fixed-and-much-faster updated file :)
If you need help for C# or VDJ Database info you can contact me, my msn address is in my profil.
You speak French or only English?
Gwenn
I speak & write both; there should not be any problems with the code though... I added you to my MSN
macourteau
For the moment I'm at work but this evening (7.00PM) I'll be at home.
Gwenn
Thanks Team!!!
congratulation on new status NAWTBOY! ;)
cool!!
57%
