These have no gui (= no graphics, so they seem very similar to regular VDJ plugins), but are very simple, and works very well with VDJ (no click, and really smooth....)
Fruityloops Plugin Pack:
- 5 band equlizer (works good)
- Balance (works w/ left-right & volume slider)
- Bass boost (works - frequency and amount)
- Overdrive (works... but don't see the use..)
- center (no effect)
- Delay (works w/5 sliders - a bit strange)
- Filter (works w/5 sliders, nice effects...)
- FreeFilter (works: low pass, high pass and more)
- mute (works.... but....LOL..turns of the music, thats it)
- reverb (don't work...)
Get the VST pack here:
Posted Fri 18 Jun 04 @ 5:29 am
Square Filter
"..Basically consisting of 4 selectable resonant filters (1 18db/oct, 3 24 db/oct) and a distortion control, this filter is extremely useful for dirtying up your sounds!... "
Really nice effects when moving sliders, but the last slider (distortion) should be keept at level 0.. :)
Download here:
Posted Fri 18 Jun 04 @ 5:55 am
Breather
Breather is a cyclically sweeping filter effect, useful for adding swooshy filter to your song.
Features:
• From 1 to 4 active variable-cutoff resonant filters offering 12dB/octave lowpass, highpass, bandpass, and notch modes as well as a 24dB/octave lowpass mode.
• Tempo selectable from 1 to 250 BPM. Filter frequency sweep range adjustable from 20Hz to 10KHz.
• Filter sweep pattern repeats from 1 to 64 times, randomizing after the specified number of repeats.
• Compact and straightforward custom GUI.
Download Breather
Posted Fri 18 Jun 04 @ 4:21 pm
Features:
• 4 independent LFO-driven effects in series: Autopanner, VCF, VCA, and flanger/echo, each with several operating modes.
• LFOs can free-run over a wide speed range or sync to VST host tempo.
• 13 unique LFO waveforms.
• Compact and straightforward custom GUI makes it easy to sound like your favorite '80s industrial noise band!
DOWNLOAD
Throbber
"...Throbber consists of an LFO driving a voltage-controlled amplifier (VCA) or multi-mode filter (VCF). Throbber is inspired by the description of the famous Throbbing Gristle "Gristleizer" effect box designed by Chris Carter...."
Features:
• Voltage-controlled amplifier (VCA) mode includes simulated overdrive distortion; distortion amount is user-controllable.
• Resonant voltage-controlled filter (VCF) modes include 12dB/octave lowpass, highpass, bandpass, and notch as well as a 24dB/octave lowpass mode, all with user-controllable resonance.
• Versatile flanger/echo mode.
• 11 LFO waveforms drive the VCA gain or VCF cutoff frequency. LFO speed is user-controllable across a broad range.
DOWNLOAD
(by the way - don't download Pegger from same site, craches VDJ)
Posted Fri 18 Jun 04 @ 4:32 pm
Stretch & Squash Produce some interesting effects... from strange things and scratch sound, to more subtile effects if fine tuned, interesting... and backward was cool!
".....Basically, a sine wave is used to modulate the speed at which the input signal is played back at (i.e. stretching and squashing the audio). To do this, a buffer is employed, which also allows the input audio to be output in reverse, hence the direction button which can be seen above....."
DOWNLOAD
Posted Fri 18 Jun 04 @ 5:23 pm
a nice tremble.....
ndcTrem+
"....this allows you to choose where in the oscillator's cycle it's reset to on the bar start, and also allows you to use it as an auto-panner ..."
DOWNLOAD
Posted Fri 18 Jun 04 @ 5:44 pm
there are so many VST's that it's hard to find out what is useful and what is not.
maybe it's a good idea to implement so kind of 'rating' so everyone can post their findings/ratings after they have tried it out?
and Dj-in-Norway, is the email adress in your profile correct? i send you an email, but got no reply (regarding VST's ;)
Posted Sat 19 Jun 04 @ 10:21 am
Posted Sat 19 Jun 04 @ 10:47 am
Posted Sat 19 Jun 04 @ 11:58 am
(UPDATE: ChECked mail - but nothing! the mail adress in profile is right. Try agian, please :) ... )
True, many of the VST's are not that good.. they work with VDJ, but still, not very usefull :)
So, I think I agree with Phenryll, lets make a Top 10 list of the BEST and most usefull VST's :) But we would have to wait a little while doing that, so we can test and find VST's first. :)
but until then, a user rating would be cool...
stars?
Like this maybe?
* 1 star (not very usefull)
***** 5 stars (best)
So that we all could put a rating under each VST post...
like this:
MY RATING : ****
just a thought....
Posted Sat 19 Jun 04 @ 3:55 pm
FRUiT94
Posted Sat 19 Jun 04 @ 3:59 pm
A topic for each of the 10 best categories maybe...
Have a poll for what the 10 most usefull plugins would be..
(1) Echo
(2) Flanger
etc :)
Posted Sat 19 Jun 04 @ 4:08 pm
Play around with sliders, so that it's not to extreme... and you get some nice results... :)
NO GUI, but works with sliders...
NILPAT: Tempo Synced Phaser VST Plug-in
"...stereo phaser with 3 modes of LFO sync: free, steps and ppq based. Nilpat is capable of 2, 4 and 6 stage phaser. Most phaser has too mild effect even at maximum feedback and they mostly are not tempo syncable. Nilpat is designed and optimized to be able to sound extreme and temp syncable..."
Features
Dry mix, Wet mix, Stage selection, Feedback, Cross signal send, sync mode, stereo phase, sweep rate, sweep width.
SUKREEP - Groove Multi-mode Filter VST Plug-in
"...Sukreep is a stereo multi-mode filter with saturation and tempo based envelope follower. Sukreep can be used as either a send or an insert effect. The inspiration behind Sukreep is classic analog filter modules essential in many genres, from wahfunk to filtered disco. I thought it would be cool to have a software version with a tempo synced decay time so Sukreep was born!..."
Features :
Dry mix, Lowpass/Highpass/Bandpass filter, cutoff (with anti-stepping algorithm), Q, Saturator (tube distortion model), Trigger Threshold, Linear/Exponential shaped envelope follower, Decay time set in milliseconds or tempo based steps, Filter envelope moduation amount.
PALI - Groove Multi-mode Stereo Delay VST Plug-in
"... tempo based Stereo/Mono Delay with alternative routings and multi-mode filters. Sukreep can be used as either a send or an insert effect...."
Features :
Pali can be routed to work as stereo delay, ping pong delay, mono delay with pan , mono-stereo delay and mono-2-tap-stereo delay. Dry mix, Lowpass/Highpass/Bandpass filter, cutoff (with anti-stepping algorithm), Q, tempo based delay is set in steps of sixteenth note, feedback and cross-feedback.
LINK:
http://members.lycos.co.uk/norsez/vst.php
(direct link not possible...sorry)
(dont download PM Percussion Synthesizer VSTi - its not a VST effect, but a VST instrument! It doesn't work with VDJ)
Posted Sat 19 Jun 04 @ 7:05 pm
Posted Mon 21 Jun 04 @ 12:33 pm
VCS UltraPhazer is a multi oscillated phaser VST plugin
"...There are 14 sliders you can control, Resonance, Min Filter, Max Filter, LFO Freq, LFO Add 1-3, Filter 1-4, Num Filter, Stereo Phaz and Mix. You can also use it as multi notch filter..."
Works great!! Gui (graphics) and all ...
Can create some really nice phazer effects..:)
MY RATING : **** (4 stars)
*** update *** direct download dont work, use this link and go the "UltraPhazer" for download : http://www.virtualcreations.de/?software?
Posted Thu 24 Jun 04 @ 2:27 pm
Any body else know that pb ?
Posted Sat 26 Jun 04 @ 10:20 am
it is an EXE file, that installs the plugin at your harddrive (feks at c:/programfiles/steinberg/vstplugins/virtualcreations UltraPhazer)...
copy the vst part (folder called "virtualcreations UltraPhazer")of the plugin to VDJ effect folder...
many vst plugins work like this, if they are EXE files. They install the plugin to your harddrive (where u choose, and by default the steinberg vst folder).
for them to work with vdj, u must copy from the steinberg folder to the vdj effect folder :)
hope that helps :)
[[ dj in norway ]]
Posted Sat 26 Jun 04 @ 1:23 pm
Posted Sat 26 Jun 04 @ 4:35 pm
A tool not very easy to use, you'll have to choose sum good sounds to convert. The plugins replaces the song instruments by drums ans beats... Kinda hard to produce some good stuffs but it's possible. No GUI but the sliders work well in VDJ.
"If you want to replace sounds on a drum track with some other sound, this is a really difficult and unreliable plug-in to use! But if you want to make some random techno noises it's fine for that."
Posted Sun 27 Jun 04 @ 11:37 am
Posted Sat 25 Dec 04 @ 3:00 am
