Sorry if I'm appearing thick? :S ! Change what from 0 to 1?
xx
xx
Posted Wed 14 Jun 06 @ 11:10 pm
did you read the topic under the link? in your windows xp run box type this
regedit.exe the registry should open up now look for HKEY_LOCAL_MACHINESOFTWAREVirtualDJ
when u click on it a bunch of stuff will open in the right window look for speedload right click it and hit modify under value data change the 0 to a 1 good luck..if u have any problems contact me on my msn
Posted Wed 14 Jun 06 @ 11:58 pm
Change the Speedload setting in the Windows Registry from 0 (old value) to 1 (new value, with speedload enabled). See for more info the link supplied some posts above this one.
Ewout
Ewout
Posted Wed 14 Jun 06 @ 11:59 pm
Much better! Not back to how it was, but as long as I put in my next tune to load sooner rather than later it's cool :)
Thanks for all your help, nice one :)
xxx
xxx
Posted Thu 15 Jun 06 @ 11:05 am
I told you in first post to search the forum about post just given by phillydj. :)
Posted Thu 15 Jun 06 @ 11:42 am
Something that I noticed no one mention is DEFRAG your drive. That might help. Also if your track hasn't been analysed before, it will be 2-3 times slower loading.
Posted Thu 15 Jun 06 @ 11:09 pm
Hellooooo, me again :)
Can someone give me the link for the speedload tweak again?
Cheers :)
Cheers :)
Posted Thu 12 Oct 06 @ 7:50 pm
it's ok, i'm being thick :o.
Posted Thu 12 Oct 06 @ 8:09 pm
did you get it?
Posted Thu 12 Oct 06 @ 8:17 pm
phillydj wrote :
sounds like maybe a driver problem i had the same problem till i updated my ati drivers and got rid of the catylst sofware.. the registry tweak did help alot u can search for speedload tweak in the forums
What did you use philly? Was it the Omegas?
Posted Thu 12 Oct 06 @ 8:45 pm
Omegas for what? the new catalyst works fine now. finally
Posted Thu 12 Oct 06 @ 8:48 pm
