I tried a search, but didnt find what I was looking for. I installed VDJ on two different machines. On one of them I get this DirectX Sound Driver error that comes up when starting up VDJ. I went and installed Direct X 9.0, but it should have already been on the machine since some of the other programs on here require it. On using VDJ though I have noticed no problem. I have not hooked it up to the system yet since I purchased the full version, but will do so tomorrow. Anybody know why this comes up?
Posted Fri 02 Jun 06 @ 10:35 pm
Try installing directx 9.0c that is the latest version and reinstall your soundcards drivers, regards.
Posted Sat 03 Jun 06 @ 12:55 am
It's because you've selected a soundcard in the configuration which isn't connected to your system. Most likely you're using an ASIO device but have VDJ configured for a WDM device.
Posted Sat 03 Jun 06 @ 2:43 am
