i recently download a skin off of the downloads on this but when i'm dj'n i find that one of my speakers cuts out when i load another track to mick in and the only way to stop this is to put the red light back on to the track that i'm currently playing on but when i go to mix in the other track the red light side is still too load when mixing does anyone know how to fix this so both my speakers will work without switching the light buttons every time i mix or could you recomend a better skin the one i'm using is loop4000
from danny
from danny
Posted Thu 01 Jun 06 @ 3:58 pm
Things to do:
- if you bought it add your serial add my serial.
- If not buy it Buy VDJ!/Buy Atomix Mp3
- Download the latest updates.
- use the default skin or a simpler one.
- check your sound config , and that your sound cards are set corectly.
Posted Fri 02 Jun 06 @ 2:25 am
