is it possible to get this working with TCD? i have downloaded timecoded cd and burnt onto two seperate disks. I have the current version of virtual dj and the hercules mk2 dj console. is it possible to get the virtual dj to work with the pioneer cdx with time coded vinyls or not? I have tried but no luck getting sync.
Posted Sun 23 Apr 06 @ 6:25 pm
Yes, you should get this working. You will need a sound card with asio support and 4 input channels (=2 stereo input channels).
Go into "Config" menu on the "Sound Cards" tab select "Low latency Time coded vinyls". Then Select the proper sound card and select "Config Timecode". Setup the proper volume here. Then it should work ok.
Ewout
Ewout
Posted Sun 23 Apr 06 @ 8:45 pm
DJ Console MK2 is a soundcard... lol still not working ay.
Posted Sat 29 Apr 06 @ 6:57 pm
