Pioneer DJM-800
"61 fully assignable MIDI controls"
http://www.pioneer-eur.com/eur/product_detail.jsp?product_id=12066&taxonomy_id=44-74
Too bad it is out of my price range.
Are there other similar products (MIDI-dj mixer controls for direct VDJ control)?
http://www.futuremusic.com/news/january2006/pioneer-djm800.html
It also seem to be able to play VDJ through it so that the Pioneer does the KEY MATCHING! So both songs play in key even if you do not use the VDJs master tempo (horrible, sorry).
Posted Fri 07 Apr 06 @ 11:26 am
Oh I forgot the Xone 3D, though it lacks the key harmonizer and is again out of my budget.
I'm looking for less than $500 dj-mixer that has MIDI controls and preferably also works as normal mixer when needed (not just pure midi controller).
Posted Fri 07 Apr 06 @ 11:52 am
Also out of your price range, but a nice mixer is the Ecler nuo4
http://www.eclerdjdivision.com/instruments/nuo/index.htm
Ewout
Ewout
Posted Fri 07 Apr 06 @ 6:40 pm
Thanks, Nuo-4 seems to be ~750 € while DJM-800 is ~1250 - 1500 €.
Posted Tue 11 Apr 06 @ 7:34 am
