I have noticed that since the release of VDJ 3.0 up to the newest revision, if you go to load a song that should be ex:134BPM if Virtual DJ analyzed it at 1/2 the bpm ex:67BPM, if the track has not been loaded into a deck and you right click on it to "edit bpm" it will NOT allow you to use the 1/2 or x2 buttons. You have to manually enter the right BPM.
However if you do have the track loaded into a deck, you can right click on the file and for some reason the 1/2 and x2 BPM buttons will work.
Just wanted to let someone from VDJ know about this.
DJ Jason G
DJ Jason G
Posted Wed 05 Apr 06 @ 7:30 am
