When using version 3.2 of VDJ and playing a song using TCV. The sound when moving the vinyl slow is a distorted electronic sort of sound compared with another version of VDJ (2.01) where the sound is the same as when using the mouse to scratch the song..........sugesting to me that version 2.01 is better than the recent versions of virtual dj. Also in later versions of virtual dj dont enable the use of an external mixer when the use of low latency vinyls are used because you cant click on the apropriate sound card button and "low latency, time encoded yinyl" any help please...........i dont want to use the older version.
Posted Wed 15 Mar 06 @ 12:23 am
It seems you are using irregular versions of VDJ (cracked versions).
If you don't buy the software, you won't be given any help nor support.
Posted Wed 15 Mar 06 @ 12:59 am
My best advice is:
1) Get VDJ Pro
2) Get a good soundcard like M-Audio 44 PCI to get your TCV's working
3) Optimize your PC, delete unwanted Temp files, buy more ram, etc...
4) You will be happy and will have a big smile in your face and less troubles for sure.
Good Luck!
1) Get VDJ Pro
Good Luck!
Posted Sat 18 Mar 06 @ 11:55 pm
